Was operating my L295DT yesterday, when stick shift started acting up. Prior to this problem, all gears and shift selector were operating normally. Now, the stick will only engage in 1st gear and the engine wants to stall if you release the clutch in that gear. It will go to neutral, and tractor can be rolled in neutral, but no other gears can be engaged.
Anybody ever encountered this, and know how to isolate the problem? I acquired this tractor with a bad clutch, and replaced that. Everything was working fine after the clutch replacement though. I'm thinking something has broken in the tranmission. The tractor does not have creep gear if that matters.
