L2850 v2203 swap injection cam problem
Unwired
L2850
Feb 14, 2015
10
Stanton, TX
Quick background: I bought the tractor with a bad motor. After an exhaustive search for a v1702 or v1902 in good condition, I settled for a low hour v2203.
Now the problem: the injection pump cam must be changed to a shaft with the splined end to operate the hydraulic pump. I swapped in the shaft from the v1702, but it the lobes seem to have a smaller base circle resulting in less lift. With the injection pump installed, pump lifters don't make contact with the cam except near the top of the lobe. I didn't take note of the fit prior to removing the original v2203 cam.
I would appreciate any comments / suggestions to help me over this hurdle.
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
Not sure if you are still reading this forum but I sent you a PM.
I am finding access to more 2203 engines as well, seems they are a dime a dozen in comparison to the 1702 as they seem to be used in many skid loader applications.
I am interested in what your final outcome was and what was all involved in the swap or if it was a direct bolt in.
Wild and Free
Oct 25, 2012
390
North Dakota
Sent you some pms to see what your remedy was on this issue? I ran into the same issue.
