kubby 2013
L2850, L3400, Jd 5103, MF 205 Ind., IH364, Jd 410 backhoe/Loader, Jd 350 Dozer,
Was reading the posts on clutches. We changed the clutch assembly on my L2850 last fall because it was slipping in 3 & 4 high. 1200 hours. We found the plates were fine looking but one of the 3 adjustment bolts with lock-nuts that the throwout bearing pushes against was worn down to and into the check-nut. The other 2 were worn only a little. No sign of any problems inside. Everything was replaced new including throwout bearing. I had to adjust the PTO clutch twice in 1200 Hrs. because it would not disengage. My brother-in -law has been a mechanic all his life and never seen a problem like this. Has anyone ever seen a problem like this? I can't find any one who has.
