David Page
I noticed that my when my split brakes are locked they aren't coming backup all the way. When I separate them the left one stays down some. I can pull it backup but it goes hard. When stepping down on it, it doesn't go easy and the brake doesn't hold like the other side. I disk connected it at what appears to be the Lever brake cam #020 on the parts list. It is hard to read the numbers when I blow it up big enough to see it well. So it appears to be something inside of the brake assembly that must not be moving well. I have the gaskets( collars) because I wanted to take it apart and see if the brake pads are alright. Now I'm wondering what other parts should be on hand. Any educated guesses? Can't tell what part the lever is attached to inside.
