Hello my orange friends
Im in need of picking some brains here. I bought this tractor this last winter
from the niebor down the road after she bought a new one. history as told to me. after we got by a tornado last summer she took it in to the kubota dealer to have the exhaust fixed that had got bent by a falling tree branch which she said the hydrolic were fading bad beforer hand. they change the the canister filter (no screens on this one) replaced the fluids (showed all reciepts) she said when they got it home they had to use the new tractor to lift the bucket so they could move it, this is after the shop fixed it. i bought it shortly after, pulled the hydrolic pump to find all seals were gone. so i rebuilt the pump but still had slow FEL (depending on the tempitures) but then start fading again and sounding like it was sucking air. 3 point seemed to work fine. i was told the l235 had a bad habit of getting pin holes in the pick up tube which i finnally got around to removing today to inspect. it looked fine with very little surface rust.the thing that i did notice that when i drained the triany down under the seat i only got little more than 3/4 of a five bucket of fuild which i would think it should have more and the fuild was motor oil color but clean. only leakes found is 1 ram on the loader. motor is clean and the antifreeze is clean and full. the loader wasnt fast moving but the 3 piont would lift my heavy 5ft brush hog off the ground at ease and when down on the ground going dowing would try to lift the rear tires. the control valve under the seat didnt seamed to make much differance opened or locked. im planning on putting back to gether replacing the right amount and type of fluids and repair the ram. IS THERE ANY THING ELSE I MIGHT NEED TO LOOK AT BEFORE I SET FIRE TO IT
IM JOKING about LIGHTING UP Im realling hoping the shop didnt put enough and the wrong type fluid in it
