l2195 Snowblower Repair questions
mtnplower
Kubota L5740
Jul 15, 2022
71
Sierra Nevadas
I was running the blower the other week and sucked up a river rock. The rock caused the chain to pull forward ripping the driveshaft out of the bearing.
I ordered this bearing, Part # #77700-00959 ..
I removed what is left of the old bearing and began to look at the new bearing
the issue is the driveshaft part # 70000-02649 does not slide into the bearing.
The driveshaft has a much bigger diamater
Are there different bearing diameter options or different driveshaft options I need to look up?
5,118
There is three different versions would need the serial number to tell you which one you have and what you need.
5,118
Well all of the sub models took the same bearing, 1/ 1/8"
So like Dustball said, what is the size of the shaft and is it possible the shaft end got damaged when it came apart?
mtnplower
Kubota L5740
Jul 15, 2022
71
Sierra Nevadas
I ordered the bearing flange and I'm ready to install everything back in
Can the bearing flange be installed first onto the driveshaft and then slide it All in or what's the best method to put it all back together?
