Hello! So my l200 has been leaking hydraulic fluid past the hydraulic piston seal into the main gear case. Recently I was mowing when I noticed oil pouring from the clutch bell housing weep hole. I was hoping the gear case had just gotten too full from the leaking hydraulic cylinder and the fluid found it's way into the clutch housing but I'm afraid that's not the case. I was able to source a u seal from a local tractor dealer and put a new seal on the hydraulic piston I drained all of the fluids and re filled. After operating for several minutes I'm again getting a stream of gear oil pouring out of the clutch housing weep hole when the clutch pedal is released..
Does anyone know how the gear oil is getting thru to the clutch is this a seal/ o ring that can be replaced witbout splitting the tractor or removing the clutch or trans?
Thanks for the help!!
