L1802 bushes
The pome
Kinchela NSW Australia
Hi
I'm in Australia but don't care where i have to access parts from.
OK my L1802 has worn out the bushed that go onto the spindle for steering. the spindle im talking about is the one that attaches the wheel hub to tractor.
Any help locating them would be great
Thanks the pome In Australia Ian :)
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
I can't make that call,
http://www.orangetractortalks.com/forums/showpost.php?p=208087&postcount=2
But if it looks good as far as the bush arrangement, I'd take a punt. There are others on the forum who may have the good oil regards direct compatibility?
I expect part for an L235 may be available via Australia, or they could order them in, if not you may be able to get them from the US via Colemans, Messicks & others.
Edit: Also try some of the aussie Kubota aftermarket tractor importers.
http://www.sotatractors.com/the-remanufacturing-process-2/
http://www.sotatractors.com/warranty-service-and-support/apollo-kubota-spare-parts/
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
If you have a win with parts, please report back so others finding this thread down the track (in OZ) may also glean some info from your results.
The pome
well sadly the L235 parts didn't fit but i did get my local engineering shop to fabricate some bushes for the :) . if you need some the size you"ll need is.
EXT 30 mm
INT 25 mm
LENGTH 25 mm
X 4
These bushes are for the spindle that is attached to you wheel hub. plus you will need the replace the lower bearing as this takes the load from the axle. These bearing are readily available
