L175 rear axle seal replacement
5,166
Not that big or bad of a job, just need to unbolt the case and remove the axle.
The WSM will tell you all the steps.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
Workshop service manual. That bell shaped axle housing must be removed. Then inside you will find a configuration of retainers to keep the axle shaft restrained. The end bearing may or may not have a bolt on seal/bearing flange. Pretty self evident when you do it. Mind you will need to drain some or all of the hydraulic fluid.
5,166
WSM (aka Service manual)
Sent you a message as to where you can get the WSM.
