The reverse on my L175 tractor would no longer stay in gear. It would jump out as soon as the clutch was released. I thought I could correct the problem by removing some free play by adjusting the Pedal Link.
I tightened the pedal link and when I went to re attach it to the Clutch Link(the flat bar that hangs down from the transmission housing that connects to the clutch link), the clutch link had moved towards the rear of the tractor and would not fall back into place. I removed the Clutch Access Plate just under the fuel filter and noticed that Hub had rotated some. I spun it maybe 5 degrees with my finger and the clutch link fell back into place. So I put the Pedal and Clutch Link back together.
When I cranked the tractor, the PTO is now automatically engaged and the gears are no longer correct
I think i have opened up a total can of worms on MAD MAX (my lil L175)
