I have a 2002 KX41-2V that I purchased used early this year and it has been working perfectly except for blowing the 15 Amp engine shut off fuse. It reached 1,000 hours so I changed the hydraulic fluid and the two filters. Everything went well except that now the hand controls are not functioning, i.e. the hand controls associated with the safety lock outs do not work. No boom, no arm, no bucket no machine swing. Tracks work, blade works, boom swing with foot control okay. Before I try and bypass the safety lock outs to see if a faulty switch is the problem does anyone have a suggestion as to what might be causing this? As I said everything was fine until I changed the hydraulic fluid and filters. I have checked the other fuses and they are okay. The wiring diagram shows the lever lock switches on the same fuse as the fuel pump so since the machine runs that fuse is definitely okay. Thanks for any help.
