Kubota D902 Bogs down under load
MotorWizz
Kubota D902 for Carpet Cleaning
Sep 1, 2014
Ellensburg WA
Hey everybody. I'm new to Kubota diesels. I have pretty good knowledge of the automotive industry as a technician for over 17 years. But I've just got this kubota D902 and it runs great at idle but under a load it likes to bog down quite a bit and I strongly feel like this is not normal. Mind you it is not under full load when this takes place. I've checked and replaced all filters, has new gas, checked for a restriction in the exhuast (its fine) and performed valve adjustment on it. Any ideas are much appreciated. Thanks.
5,180
OH I think I know exactly what your problem is! :p
has new gas.
Try using diesel, :eek: It will run much better! ;)
Ok now if that was just a typo, then your problem lies in fuel delivery.
One simple test, remove the feed line to the injection pump and feed it fuel from a bottle and hose gravity feed from above the injection pump.
If it works then there is a problem with fuel delivery to the pump, if it doesn't help then it's fuel delivery after the pump.
Could be clogged injection pump, or clogged injectors. :cool:
