Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Selling my Kubota B9200 4cyl Diesel tractor, BF350 Kubota detachable loader, HST 3spd trans, power steering, 4wd, new front tires and one new rim, good rear tires, 3 point hitch, mid pto (to attach mower, snowblower, etc). Auxillary light bar with LED and halogen lights adds great night time visibility.
There are some minor dents in the hood and the 3 point shroud, both do not affect the function of the tractor.
Approximately 1212 original hours as of 4/2/15. The hour meter turned over once while I have owned the tractor.
Included: RC60 shaft drive belly mower with 60" (5') cut. Mower spindles, blades, belt and gearbox are in great condition and work perfectly, however the deck has some wear that does not affect cut quality.
Negotiable: 7' county line plow/grader blade with good cutting edge included in picture.
Custom made tooth bar available and negotiable as well.
Machine starts, runs and drives perfectly, all items function as they should. No smoke, oil consumption, etc. Machine has been immaculately maintained by a diesel mechanic. New Shell Rotella oil, kubota oil filter, kubota fuel filter, oem hydraulic filter, and air filter replaced every 100 hours. Machine has a fresh change of Kubota Super UDT2 (synthetic).
STRONG hydraulics on this machine, a fresh cutting edge is welded on the bucket with lift hooks, and all fittings/pins take grease. I have been able to lift over 800lbs with this amazing tractor.
Operator manual, spare filters, spare tire and rim, and some other items available as well.
Selling to buy a larger tractor.
Kubota B9200 Engine:
Kubota 1.2L 4-cyl diesel
full engine details ...
Capacity:
Fuel: 5.3 gal [20.1 L]
Hydraulic system: 4.75 gal [18.0 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 1,279 lbs [580 kg]
Rear lift (at 24"/610mm): 1,014 lbs [459 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPMs: 540/748
Mid RPMs: 1847/2557
Dimensions & Tires:
Wheelbase: 62 inches [157 cm]
Weight: 1570 to 1676 pounds
Kubota B9200 attachments:
mowing deck
front-end loader
Kubota B9200 Power:
Engine (gross): 22.5 hp [16.8 kW]
PTO (claimed): 16 hp [11.9 kW]
Mechanical:
Chassis: 4x4 MFWD 4WD (optional)
Steering: hydrostatic power
Brakes: dry internal expanding
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Capacity: 4.75 gal [18.0 L]
Pressure: 1930 psi [133.1 bar]
Valves: 1
Total flow: 7.1 gpm [26.9 lpm]
Battery:
Number: 1
Volts: 12
Delivery is negotiable.
$8800 obo.
Capacity:
3-Point Hitch:
Rear Type: I
Rear PTO: live
Rear RPMs: 540/748
Mid RPMs: 1847/2557
Dimensions & Tires:
mowing deck
front-end loader
Kubota B9200 Power:
Mechanical:
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Valves: 1
Battery:
Number: 1
Volts: 12
$8800 obo.
