Kubota B6100 1977
5,130
Looking to buy rear pto drive gear
66711-1453-1
17 tooth
Any help?
First don't look at a printed list of parts, they are severely outdated, and have the wrong part numbers listed, all Kubota parts number follow XXXXX-XXXXX format currently.
and when you see a part number that is XXXXX-XXXX-X you know its wrong.
Use the Kubota site to get current part Numbers: https://apps.kubotausa.com/illustrated-parts/
The real P/N is:
66711-14530
superceded to
66706-14530
There is some confusion if the two parts can be interchanged without changing other parts in the assembly.
so look closely at your original part.
P/N 66711-14530
https://www.stavros-savva-co-ltd.co...sion-and-pto/kubota-gear-17tx18t-b6001-b7001/
P/N 66706-14530
https://www.ebay.com/i/264362329643?chn=ps
Panfarm1977
Harrison ohio
Thank you so much for your help to find the gear, we have found the bearings etc.
I can not find one other gear 18 spur the original part is
66711-1449-1
Any chance you could help again to find updated part number or the part on eBay!
I really appreciate your help!
Thanks so much!
5,130
Is this the gear you need, and if so what is the serial number of the tractor?
As that will determine which gear you need.
If you need 66711-14790
http://www.yenibiz.co.uk/pto-sprocket-kubota-832.html
If you need 66706-14790
http://www.mainetractors.net/kubota-b7100-parts/kubota-B7100-parts.htm
From the looks of it they appear to be the same gear????
If the serial number says 66711-14790, check it against these measurements as the 66706-14790 might work.
https://www.stavros-savva-co-ltd.co...ission-and-pto/kubota-gear-pto-18tx18t-b7100/
