Kit detent woes - lost balls
suffering_jukebox
L3450
Aug 29, 2021
New York
Replacing some seals on a leaky spool of our L3450 (FEL LA650a), and despite having some magnets at the ready, two of the small balls at the bottom of the spool slipped away. New kit is $140, but I really just need the two tiny balls that go in the rod I think they’re 3.8mm. Labeled A below:
A few more pictures of what I mean:
Thanks to @srr5008 I hope it’s ok I’m using your pictures
ken erickson
Nov 21, 2010
1,018
1,587
Waupaca Wisconsin
I have found McMaster-Carr a great source. Getting a accurate measurement of the size ball is going to be key. I also quickly clicked on these 440c stainless ones. There maybe better options for your application. I will let others weigh in on that. Good luck!
hardened-bearing-quality-440c-stainless-steel
RBsingl
Kubota F 2690 72" rear discharge deck, Deere 955
Jul 1, 2022
408
425
Central IL
If you have a local bearing supply house in your area, take one with you and they will match them up for you.
Otherwise McMaster will have them.
Rodger
suffering_jukebox
L3450
Aug 29, 2021
New York
Incredible, 3 answers within 15 minutes of posting- magnitudes faster and more direct than ringing my local dealer. Thanks for the info y’all
Sparky Prep
177
245
South Florida
Second on McMaster-Carr. Great supplier. We use them at work, very large electricity generating facility. For acurate ball diameter measuring, invest in a quality micrometer/ caliper.
3,549
Or even a cheap one.
suffering_jukebox
L3450
Aug 29, 2021
New York
Oof- yeah you know, as I sock some cash aside for that professional one someday- Amazon’s got one for 10 bucks which seems…serviceable for the time being haha
3,549
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,819
897
Near Lancaster, PA, USA
Two local hardware stores stock the balls. I took a sample ball and the caliper I use for reloading. The measurement was confirmed by using the caliper as a "go-no go" gage.
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
Something I've done for years, started at work. I'll cut the outer race of scrap bearings and save the balls. I have a few spray can caps full of various sizes. When I loose a detent ball, I usually have something close enough.
