J-Bar Bushhogs??
jd57
L225, kingkutter 4' bushog,A&B 4' boxblade
Dec 14, 2014
38
hilham,tn.
I have a Kubota L225 tractor,3cyl diesel,24HP. I'm looking at a 4' J-Bar. I'm bushhogging 7 acres of pasture grass. Whats y'all opinion on this piece of equipment?
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
ooh... I have 6 acres that I only cut about 5 of them and it takes pretty much all day with a 60" cutter. I can only imagine how long it would take with a 48" one... :eek:
4,750
Took me about 1 1/2 hours per acre of field with my 4ft howse. That was horse pasture where they chomped down most of the grass. So I was going behind the horses and knocking down the rest of the weeds, and saplings trying to take over.
Got into some real thick grass and weeds at the neighbors, and that took the better part of an hour for the 1/4 acre spot. But that stuff should have been hit two months earlier and was as tall as the tractor :rolleyes: The old bota kicked butt though :D just dropped it into creeper gear and puttered along :cool:
It's gonna depend on what exactly your mowing and how thick it is.
1,019
I have a L185, a bit smaller tractor than yours. A 4 foot mower is all that I want on my tractor due to the unloading of the front end. Even with the 4 foot, I ended up adding weights to the front to help balance back out the tractor. I mow about 3.5 to 4 acres and it takes a good 4 to 6 hours - lots of trees and such to avoid!
For the L225, I think you can use the larger 5 foot - if you have all the suitcase weights that will fit on the front. If you have no weight on front then you will probably need to get them to use the 5 foot mower. You may not have to have any weight for the 4 foot.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
With my L2202 and a 4' bush hog, in moderate weeds, I can do 10-15 acres a day. Kinda subjective to site conditions, sometimes you have to gear down to go through heavy stuff. At home, after I fixed the throttle, I did 6-7 acres of cow pasture, in December, in about 4-5 hours, if I recall right.:D
jd57
Dec 14, 2014
38
hilham,tn.
My pasture is wide open,2 treesto go around. I used my neighbors international 384 w/ a 5' bushhog last fall and took me 6hrs. to cut it. The grass was about 4' high.
Russell, good point on the weights, I don't have them!
Do any of you fellas own or know someone that owns J-Bar brand. I'm wondering if they are good or are they junk.
I compared them with the bushhog brand & the steel gauge is the same thickness (14 gauge)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I have owned a J-Bar cutter and it was a real POS. I guess it would be better than not having anything but if you can afford better it would be money well spent. Don't get me wrong, the people at J-Bar are great. Their facility is only about 30 miles from here so I would love it if the implements they made were quality but there not. I've tried several different implements from them and all were way to light. Bend, break or just plain fall apart, it's going to happen.
If you're just clipping pasture you probably would be fine with a 5' cutter. If nothing else hook it up 2 point so the tractor won't have to pick up so much weight.
jd57
Dec 14, 2014
38
hilham,tn.
Thank-you Bulldog,thats what I wanted to find out. don't mind spending more money to get better quality.
What brand 4' bushhog do you guys recommend?
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
428
35
Red Springs, NC
We have 2 Hardee 5' tigercubs 40hp gearbox. Hardee is made in Loris SC. I have ran several different brands and my opinion is this is the best mower offered in our area. As far as J-Bar, only looked one day I passes buy the dealers lot, looked and left before the salesman could get out!!
Bulldog
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I have Bushhog brand cutters and have had very good luck with them. Don't worry as much about which brand, look at the specs. If you want a high quality cut compare blade tip speed. The faster the speed the better the cut. This is what kills the J-Bar cutters, their tip speed is very slow and they cut like crap.
If I was looking for a 4' cutter:
Bushhog BH14
Land Pride RCR1548
This may fit your needs. I suggest trying to stay with a BTS of 13K or faster. My 5' is around 13K and it cuts well. My 8' is around 15K and it has a higher cut quality than the 5' does. Just a small difference in speed makes a huge difference in the cut quality.
jd57
Dec 14, 2014
38
hilham,tn.
Thanks bulldog,helpful info. I have another novice question. My tractor has a "hi" & "low" speed on the PTO, which sould I use when bushhogging?
Oct 8, 2014
623
oregon
That 3' difference in diameter is what gives you a faster tip speed. Same math with the same gearbox will give you slower speeds with the 48". The slower you drive the better cut you get too.
Bulldog
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I don't recall ever seeing a implement that runs slower than 540 rpm but lots run at faster speeds. So just making a guess the low is 540 which is what you will need to run a cutter.
