I finally got the D950 up and running in my B7100D-T... I had to make some pretty creative coolant piping adapation (it was a thermosiphon D750, now a waterpumped D950, but still using the old radiator), but it's hooked up and working. Re-filled all fluids and assembled enough to run it around. I still need to machine a front PTO shaft adapter to bolt to the front pulley to run my FEL pump, but it was feeling like this project was wrapping up.
The next challenge may have already presented itself. When running along flat ground at high speed (high 3rd gear at more than half throttle in 2wd) there is an occasional/intermittent squealing that sounds like it's coming from the front of tunnel between the bellhousing and the gearbox. First though was the throw-out bearing, but it makes no difference if the clutch all the way out or with light pressure on the pedal. It sounds like a dry bearing kind of noise.
Maybe a failing bearing for the front driveshaft? Are the bearings in the tunnel lubed by the transmission/hydraulic oil?
Any thoughts or advice?
