Never pulled off an injector and wanted a gut check on the process from someone who has.
The manual states: With pressure and bleed back lines removed, unscrew injector from its mounting position on cylinder head.
[/URL][/IMG]
I'm assuming they mean unscrew the whole assembly at what is part 070 in the diagram, and NOT part 010.
Should I heat the block (run the engine briefly) prior to this to assist in removal?
I have a feeling these have been in there since 1980.
Would you suggest some PB Blaster or WD or penetrating oil to assist in the removal?
Is it worth attempting to clean on my own (as a novice at this), or would you suggest just turning them in for inspection, repair?
Blackjack.
Blackjack.
