Y yoop New member Nov 9, 2016 7 0 1 Junction City Wisconsin Nov 16, 2022 #1 I need to know the correct size bolts to attach my radiator back on my L345dt. Any help?
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 10,017 4,115 113 Greensville,Ontario,Canada Nov 17, 2022 #2 just goto the Kubota online 'parts finder', locate your machine, scroll to the 'cooling system', zoom in and check the list. if the bolts aren't 'sized', copy part number then paste into Google... 3-4 hits later will show the actual dimensions...
R Russell King Well-known member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 4,707 1,011 113 Austin, Texas Nov 17, 2022 #3 Kubota hid the radiator support under the front axle section part number is 15108-72380 Picture of the bolt at 15108-72380: Kubota BOLT- RADIATOR SET Construction/Agricultural component cross references to KB15108-72380. Weight: 0.094 lbs. Online Ordering. Nationwide Shipping. shop.moderngroup.com
