pinstripefan90
BX25D, FEL&BH, Piranha tooth bar, Bucket hooks, Pallet forks, Back blade
So, I bought my BX25D used from a dealer in August and it had 225hrs on it and had just been serviced, it now has 285hrs on it and with the extreme cold we have had here it developed a small hydraulic leak from the filter, no much of a leak but a small drip while parked, I bought a filter and super udt 2 fluid today from Kubota and serviced it this evening, when I removed the filter I noticed it was misshapen and the filter material inside was loose and collapsed, I installed the new filter, drained the fluid, cleaned the screen (which was pretty clean to start with) filled the fluid to spec and ran it, I noticed my hydraulic whine which was minimal before is now gone...just wondering if you guys have ever had this issue with the filter before, I assume it must have just happened when the leak developed and luckily I hadn't run it since I noticed the leak. I'm a mechanic and I have never seen a filter do this and I find it odd, anyway let me know if you guys have seen/had this happen, thanks.
- Jake
- Jake
