Anyone use or see a hy reach clipper? I like the distance from the tractor. Does my L3800 produce the 2000 psi hyd pressure needed? Also check out their extra hyd port kits, look east to install but what would pros and cons be? What flow rate is hyd fluid on the L3800. They also have a 3 point clipper that would allow you to have brush forks on front. Thanks for your help!!!
