Wolfman, thanks for the kind offer. I think that I am able to do the repairs on the Bosch relays- they can be opened; issue/concern is with the light wire on the coil and subjecting the heat from the soldering iron (I've got experience with soldering though).
OK... I ran tests this morning and I find that I get the solenoid clicking when I jumper, on the OPC wire harness (unplugged), the red/white wire to the white/blue wire. I first check to ensure that the continuity on the white/blue wire was sound: I also used a light bulb in-line to act as a fuse (as well as the tester light's) so that I didn't have to worry about messing up the wire.
The good news is that the shutoff relays are good. Well, that they are properly switching at 12v.
The bad news is that the voltage coming through the OPC isn't enough to switch the relay.
Again, I'm seeing roughly 6v here.
Is the OPC bad? It seems to be doing everything it's supposed to do (I can mess with the safety switches and cause it to not allow the starter to be engaged), but only allowing 6v (instead of 12v) to the shutoff relay? That seems to be a rather nuanced failure.
I know that I'd removed the tap that I had to the OPC's red/white power for my light circuits and that that didn't have any effect, which would mean that those circuits are not interfering (now).
Could I have damaged the OPC during my screw up with the first installation of the light relays in which I'd had the switching reversed? Again, any such damage seems pretty nuanced: I'd figure that damage would result in an internal short (very obvious).
Any way I can verify the integrity of the OPC? Some resistance numbers I could check against? How much is an OPC?
Is there any mechanical activity in the OPC that might have something sticking? Maybe smacking it might make it work (I need some additional outlet for my frustrations!)?
