How to remove pulleys on a RC48-G
300zx
Dec 1, 2010
445
Forest, VA
It is time to clean up the deck for the G5200 we bought for my Grandson. I have everything off of it but the outer spindles. It will get sandblasted tomorrow and then on with the weld repair on the holes in the top of the deck. So, how do I get the pulleys off so I can remove the bolts holding the spindle casting? From the parts diagram, it looks like my only choice is to drive the keyed shaft out of the pulley. What I don't know, is if I drive it out, will the key hit the upper bearing and stop it. Anyone have experience with it?
John in VA
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
353
Homer City, Pa.
No you don't have to remove the feather key, but I usually do so I don't loose it, the key is for the pulley, not the spindle as the pictures below will show.
Big Kahuna
300zx
Dec 1, 2010
445
Forest, VA
Big Kahuna
Thanks, I didn't realize the shaft stepped up. As I said, I thought it was the same diameter as the inner race of the upper bearing and would stop the shaft from going very far.
John in VA
300zx
Dec 1, 2010
445
Forest, VA
The key does catch on the inner race of the upper bearing, so I had to use a narrow drift punch between the pulley inner diameter and the threaded portion of the shaft. After soaking in penetrant all night, the shafts finally came out of the pulleys and I got the spindle castings off!
John in VA
Big Kahuna
Dec 23, 2011
353
Homer City, Pa.
Like I said I take the dang little thing out because losing it sucks.
I'm tearing down a RC60-71B right now, hope the weather holds with me till after gobble day and I get it painted.
Big Kahuna
300zx
Dec 1, 2010
445
Forest, VA
Big Kahuna
I know what you are saying, but I couldn't get the key out. It was stuck in the pulley. So my only choice was to drive the shaft on down, leaving the key in the pulley until the pulley was loose. Then the key came out with the pulley.
John in VA
