How to change belts on Woods 990
Fatdaddy
9
Jackson Tenn
I was cutting at church and the cutter was half cutting not cutting very good.
I got somebody to sit in and turn on the cutter and all blades were moving.
I took off one side and the belt was lose.. Just seem to lose.
Im wondering if belt is to lose why am I not getting a good cut..
I had been cutting 2 hrs straight..
I was wondering about why if the belt is to lose...
Is there a site to see how to change a belt?
I also got something else on my Kubota tractor L series It keeps dying on me just cuts off.. Last week a guy told me about the top fuse burning out..
It did it 3 times today just cuts off... Why is this?
I not having a very good day
Tks
Dave
Tennessee
5,184
Check the seat safety switch.
Go to woods site and download the manual for your mower.
Fatdaddy
9
Jackson Tenn
I took both covers off and I can with my hand take the belt OFF the pully real easy.. Is that normal??
Im looking for a site that shows me how to get a belt on the right way..
Woods 990
I had a guy sit in the tractor and run the cutter.
I looked under it and all 3 spindells were moving but you put down the cut and it
does NOT cut very good at all..
5,184
I need to know the exact model number to help you out, as woods has several 990 models.
Fatdaddy
9
Jackson Tenn
Im at work tonight(steel Mill) I did find this the pic shows a 8" spring to a Ibolt connected to the front rt middle. I go by there on my way to work tomorrow night see what I can find model number this manual was for 2008 model.. I got the pic that goes with the info below.
At least I know more about than I did at 3pm today
Tks for your replys
cause personal injury.
Belt replacement is accomplished in these steps:
1. Loosen nut and swing belt guide (G) away from
pulley (F).
2. Loosen nut on eyebolt (H) to relax tension in
spring.
3. Slide belt under and around drive pulley (A).
4. Route belt around pulley (F), idler (E) and pulley
(D) as shown.
5. Make sure belt is on drive pulley (A) and route belt
around spring-loaded idler (C).
6. Grasp belt between spindle pulley (B), springloaded
idler (C) and spindle pulley (D). Pull springloaded
idler with belt and route belt over pulley (B).
7. Tighten nut on eyebolt (H). Make sure springloaded
idler arm pivots freely with belt installed.
8. Set belt guide (G) 1/8" away from belt. Tighten to
Fatdaddy
9
Jackson Tenn
It was the spring broke in half.. I took the I bolt half out..
Now that spindell/pulley there is one bolt to take off but that pulley is not coming up.. tell me how do I get that one off..
Im not the sharpest knife in the drawer.
5,184
HAHAHA :eek:
Can you take a picture of what your working with and post it?
or
Is this the set up your looking at?
Fatdaddy
9
Jackson Tenn
I got it off and the broke half off so going to Tractor place and get one tomorrow and ALL IS WELL..
tHANK you sir and the others for hanging with me.
Now I got to deal with this wires something touching the frame
