High "low" engine speed question?
Jim Bud
B2650 HST, 60"mmm, LA534 FL, 72" rear blade
Nov 8, 2017
15
Sedalia, CO
I have a brand new B2650 and I'm wondering what the correct "min." engine speed is supposed to be?? The slowest engine speed is about 1120 rpm....what is the slowest speed supposed to be??
Thanks
2,737
Thanks[/QUOTE
Newer BX series idle and 1400+
I think the B7100 is close to 1000, mine has a tach. If I try to get below that get pissy and then cuts off (fuel is shut off) but at 1000ish is purrs.
I would say that 1100 is good;):)
kenmac
B26 with hyd. thumb and 4 in 1 loader bucket and EA Grapple, but not the wicked
Dec 14, 2015
92
9
Pell City, Al.
Generally, the smaller the diesel engine, the higher the idle speed. My B26 idles at about 1050 and is fine at that.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
I have an older B-6200 and warm up @ 1200 for a few minutes then run it up to 1600rpm for a few more. After that it's WOT baby!!!
armylifer
Mar 26, 2013
2,101
851
Thurston County, WA
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Thanks
The idle speed on mine is the same as yours and is correct.
lescarpentier
B3350
Oct 12, 2016
73
Washington
Thanks
The low idle spec is listed as 1100 rpm.
So 1120 is as close to perfect as you get.I wouldn't want it any lower as the oil pressure is only about 7 1/2 pounds at idle according to the specs.
