WinnieCouple
L245DT, razor brush hog, small disc, double bottom plow, 5' Turfline Box Blade.
I have a L245DT with a FEL, and a few weeks back the front frame assembly snapped a corner off of the engine block at one of the mounting bolts. *using the FEL and NOT overworking it...
WELL... after getting her up on stands and and pulling the entire front end off. All I can say is it was a POOR DESIGN for the front end of a 4x4 tractor.
Yes, its only 25hp, but I'm sure its NOT the only tractor to have this problem.
It looks like its had 4 helicoils, and one stepped up/tapped out larger. So, its been a problem for this tractor.
So... buying and replacing the BLOCK is out of the question, it wouldnt cure the problem.
My intent is to fabricate a front subframe, bolt some plate to the sides of the block, weld some 4" channel from the bell housing to the front bumper ( it has an 8" C-channel bumper).
Bolting the front of this subframe to the bumper, and adding 2 anchor points to the FEL mid body supports, and welding the front assebly to the new subframe.
This way, the tractor can be "split" (if/when needed) and the new added metal would come off as part of the front assebly.
Has anyone seen or attempted anything like this?
I'm sure its not the first.
It should be much stronger than the orriginal design.
I'm also going to fully weld up the front "swing open" FEL frame, attaching the hood with pins so it has to be lifted out.
I'm not making a dozer, but it will be SOLID.
any guidance or suggestions before I start....?
Thank you.
Thank you.
