Hello, I found a leak on my kubota b7200 hst 4wd at the brake lever on the brake housing on left side of tractor. I looked up parts and there appears to be a o-ring there. My question is, is it possible to pull the brake housing cover without draining the hydraulic fluid? And would there be other seals internally allowing the fluid to get in there? Any help would be appreciated! Thank you!
