I have an L35 with BT900 backhoe. A hydraulic hose feeding the boom piston ruptured due to chafing against the pin. I have now replaced the hose and find it almost impossible to get the pin back in the boom piston due to the limited capacity available for the 6 hydraulic hoses and chafing sleave that must be routed through this small space. Perhaps the diameter of hose I used to replace the old ones is too large. Does anybody know what the hose diameter (outside) should be? Or have any other ideas on how this should be done correctly. I can see myself smashing the boom piston back in place but I'll just be in the same spot next year as the new hoses chaf. Just doesn't seem right. Thank you.
I've attempted to attach some picture of the old configuration, when the hose ruptured, which are the pictures with the yellow chaf gaurd. Also, a picture of the new hoses installed with the blue chaf gaurd. Thanks again for any advice you might have.
