Help installing Tachometer Assembly
Kennydog1
Kubota L1801
Feb 24, 2014
21
winnsboro, La
I have an L1801 grey market and bought new tach. assembly that attaches by injector pump. When I get ready to install the new tach. assembly:
1. Do I need to put grease inside the assembly?
2. Do I need a gasket for where it installs on the engine? If I do, what kind of gasket.
Any help appreciated. Thanks.
4,793
You can use black rtv to seal the surfaces. Just make sure and clean the surfaces. I didn't put any grease in when i did mine, wouldn't hurt though;)
Kennydog1
Kubota L1801
Feb 24, 2014
21
winnsboro, La
As always my husband and I thank you for your help. The hardest part was removing the existing tach drive, After that assembly went smooth and IT WORKED!!!!! Thanks
