HELP-fuel guage stays on full
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
12
Northern California
Gee, I wish I had that problem.
Kidding aside, more information is needed. It could be the sending unit, the float, the gauge, the relay, the fuse, or anything in between.
Check ohmmeter readings between the various components and ground. When the tractor is off does it still read FULL? Is it usually on E when off? What is the voltage from the sending unit? Does it change when the tank is at different fill levels?
Can't say I'm an expert on such things but list what you have tried and one of the knowledgeable folks on the forum may deduce a fix.
joekimtkd
B7510DT, 4' Snow blower, 4' Loader, 6' Blade, 6' 3PH Finish mower, 6' box blade,
Aug 16, 2009
204
Durham Ontario Canada
As GWD said, See if gauge still says FULL even though tractor is OFF.
If it is, Gauge is bad... That is simplest to narrow down the trouble shooting.
Good luck.
Joe.
