So I spent some time servicing my BX2370's 60" deck the other night and have a question about the volume of grease. When dad taught me how to grease equipment 20 years ago it basically went like this.... Pump a little grease until you see it start to ooze out then stop. Pretty easy, and useful info that has served me well. I noticed on the BX deck though that this isn't the case either because im doing it wrong or some of my grease points were bone dry and seemed to have a 5 gallon reservoir?? The u-joints and deck pivot point both no problems, couple pumps and grease oozed so I stopped. The one on the rear of the deck (that has the arm with spring attached) just wouldn't take any grease no matter how hard I tried to pump the handle so I stopped before I caused problems.. The big question though is the spindles.... I pumped one of them like 10 times and never saw any grease ooze out anywhere so I lifted the deck and checked the bottom to see if it oozed there and the same....no grease. How much grease do you need to put on those spindles? I read somewhere that they are under filled from factory and people have put like 90-100 pumps before grease fill the cup and ran out on bottom. Im ok with doing that I just wanna make sure its correct and im not damaging anything or blowing out some sort of seals (if they exist) on the deck. Give me a little insight here please people...
