Hi, new to the forum and new owner of a L3301 and have a quick question I hope someone can answer. The tractor has 38 hours on it, purchased in June, this year. I have tried repeatedly to put grease in the front right zirk on the tie rod end closest to the tire and cannot get it to take grease. Have taken the zirk out, put it into the grease gun and grease flows freely, but when I put it back in I cannot get grease into the fitting. The tractor was supposedly serviced prior to delivery but it does not feel like there is any grease in the seal.
Called the dealer and spoke with the service department and was told I would need to bring it in and they would check it out, and fix if necessary under warranty. The guy I spoke with said its probably just dirt and needs to be cleaned out. I used a small awl to prod around in the fitting and there does not appear to be any dirt inside. We live about 70 miles from the dealer, would have to rent a trailer to haul the tractor (twice) and two trips down and back, since we would have to drop it off and leave it.
Any suggestions as to how to get grease in the fitting? Only solution I can come up with is remove the tie rod end and take it in. Thanks Dan
