Hello,
This post is directed at one of you friendly servicemen, or someone who has experienced this problem. On my rear axle, left side, the glide steer actuator (right name?) appears to have a fluid leak where the shaft enters the axle housing. I'm assuming there is a seal on the shaft leaking. Is this a common GR2100 problem? Can the seal be changed from the outside of the housing? How do I get the actuator shaft out if I can change it fom outside the axle housing etc. etc. . The leak isn't bad yet....just a couple of drops on the garage floor after each use. I posted this in someone elses thread and didn't get any response, so I thought I'd try it in it's own thread. Thanks in advance for any help.
