Front loader works, 3 point don't
Dusty1948
L 2800D with Front loader
Oct 20, 2016
Ozark, AR
Just changed out my loader controls with a new Prince MB21BB5C1 2 spool loader valve. The one that came on the tractor (L 2800) was damaged in a storm. changed all the fluids and filters. I made sure that I hooked up the power beyond hoses correctly. I put in 8 gals of fluid. loader works great but 3 point will not do anything. also after putting in the fluid I still can't see any fluid in the level viewer. Help:confused:
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Need to top the fluid level off but if the loader works that isn't the real problem.
What is the 3pt doing?
Is it stuck up or down?
5,128
Two major possibilities things come to mind.
Loader valve is not set up properly:
Either IN, PB, or Return is not going to the right place (seen IN and PB swapped, and PB and Return swapped) or the valve does not have the right PB adapter installed.
Did you install the High Pressure carry over plug?
Dusty1948
Oct 20, 2016
Ozark, AR
all fluid levels are up to required levels. I noticed that the old control has a power beyond port on it to. Ive check my other hoses and pressure and out is correct. 3 point is down
Dusty1948
Oct 20, 2016
Ozark, AR
there are plugs in the extra IN port and extra OUT port. not sure if they are high pressure. they each have o rings on them and allen head to loosen or tighten. Both out hose and pb hose are, I assume, sending fluid back to tank.
5,128
It's a small plug that fits inside the port for the PB.
And only the PB port should flow fluid when the load valve is not in use.
PB should be in the side port only and the return can be in side or face port
Dusty1948
Oct 20, 2016
Ozark, AR
Thanks so much for the info. I'm trying to get that high pressure carry over plug from a Vendor close by.
madbarney
b8200
Oct 14, 2016
12
cedar hill
Hi Dusty. Maybe you can call Northern tool Parts Department at 1-800-222-5381 to get the PB plug.
