The tube/rod that connects the 2 latch plates together is either bent or broken and the latch plates are not clocked the same any more.
Your either going to have to cut the tube/rod out and replace it, or sometimes you can bend it back, you do that by stopping movement on the plate that's leading and use the hydraulics to push the other out till they are clocked the same.
HI MPHAM - Mine twisted when the quick release failed, and the grapple fell off on one end.I did the same thing to mine with a stump bucket that wasn’t quite built to spec. It fell off and twisted mine. As said above a block of wood on the piston got it back in time.
See your other post on this same issue:HI MPHAM - Mine twisted when the quick release failed, and the grapple fell off on one end.
So, now I cannot get the mounting plates on my bucket because of the tweaking.
Question: How did you use a block of wood to fix the twisting on yours?
It could save me $850.
PS - That quick release, quick mount is a flawed design in my opinion.
