First real tractor
Shepbear
B2650, SSQA 60 inch bucket, QA with BB1260 box blade
Jun 1, 2016
21
San Tan Valley, Az
We bought 2 acres here in San Tan Valley, AZ, and have a house going up. Land is cleared, but I have to spread 60 to 80 tons of granite. I'm 70 with two knees needing replacement. After a lot of on line research, driving various Kubota, JDS, and MRS, and talking with others, I want a Kubota. I've had two IHS and one Simplicity garden tractors over the years, and while they were OK for mowing three acres, they would not suffice for what I need now.
No lawn, but I'd like to build an rc car track, some driveways, do some grading and maintenance. I think a bx2670 with a fel and box grader would do it, but the I drove a b2650. Looking at that with a 60 inch fel and a 60 inch box grader. Probably my last tractor.
Thoughts?
TripleR
Sep 16, 2011
1,911
SE Missouri
Yes, a BX will do it, I have two, but for your situation, I'd buy the B2650 hands down.
Missouribound
Jun 17, 2014
646
37
Missouri
I recently bought a B2320 after looking at both the L and the BX series tractors.
With the box blade and fel I can do just about everything I need on my 5 acres.
You can add a mower if you need but is seems like a garden tractor will take care of those needs. Shop around, Kubota still has the 0% 84 mo deal on tractors.
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
Any BX including the 1870 will have zero problems getting done what you need. The B obviously would be great as well but the question is will it do anything that the BX won't do and based on your wish list I'd say no. Save the $$$.
I was in the same position 3 years ago when I was shopping between a JD, BX 1860/BX25 and B series. I heard from everyone to get one bigger than you think you need and here I am 300hrs later on my "little" BX1860, still confident I made the right choice.
Thorny
L2501 HST, 4x4, FEL, front snow blade, rotary cutter, box blade
Sep 24, 2016
91
Mountains of CO
both the B and BX will spread your granite just fine. But I wonder if the B will be too big for the work on an RC track. Most of them that I've seen over the years have tight turns and transitions that the B might be too big for.
TripleR
Sep 16, 2011
1,911
SE Missouri
With the B2650, you will get a much smoother ride, more comfortable operator platform, tilt steering etc. as well as a position control 3PH.
The only reason I have SCUTs over Bs is I have several tractors for heavier work and I use my SCUTs mostly for mowing.
At my point in life, money is less important than picking the best machine for the tasks at hand. For those who finance, monthly payments aren't going to be all that much different. I pay cash, so while it hurts worse initially, it doesn't last as long.:)
Shepbear
Jun 1, 2016
21
San Tan Valley, Az
Thanks again for your thoughts. The rc race track will be an oval about six to eight feet wide, just dirt. Not sure how long it will be. It'll have a platform in the middle for operators to stand on and turn to face the car at all times. Maybe some plastic pipe or some other material for sides of the track. Plan to build some jumps and washboard areas.
Spreading the gravel will be a chore, so I figure the bigger fel and tractor will help.
2,872
The BX will do everything you want to do, the B will too, but at a bigger price tag.
4,436
Shepbear, I'd follow TripleR's advise. Go for the smoother ride, tilt steering, and better 3 point hitch control. You're at the point in life you need to enjoy your decisions.
Concerned about spending your kid's inheritance? NO...it's yours. It's only theirs after you're done and assign it to them!! Enjoy life.
TripleR
Sep 16, 2011
1,911
SE Missouri
As acknowledged, yes a BX will do it, BUT for a 70 year old man, (I'm 69) with knee replacements on the property mentioned, a B2650 will, in my opinion, be the hands down best choice.
Things you get with a B2650 you don't with a BX:
1. 3-range transmission.
2. Tilt steering.
3. Steering brakes.
4. Telescoping stabilizer bars.
5. Telescoping lower link ends.
6. Dual pump hydraulics.
7. Position control 3PH.
8. 14.6" ground clearance.
9. Mounting step. Yes, some of us older guys have problems mounting dismounting a BX with the deck removed, tere are numerous threds on this with add on steps.
I'll echo what D2Cat said, spend it and enjoy life, I certainly intend to..
Shepbear
Jun 1, 2016
21
San Tan Valley, Az
One other question. Quick attach or pin for the fel? I really do not see taking the fel off very much.
TripleR
Sep 16, 2011
1,911
SE Missouri
Quick attach to be safe. The list of things I didn't think I'd ever "need", but have now is embarrassingly long.
4,126
Shepbear, I'd follow TripleR's advise. Go for the smoother ride, tilt steering, and better 3 point hitch control. You're at the point in life you need to enjoy your decisions. Enjoy life.
I was with TripleR, and D2Cat said it all very well supporting TripleR.
If you're not mowing, and need to move dirt, go bigger than smaller if you can afford it.
My one question is RC track? What size track are you looking at? Love to see a picture of two of one of those vehicles, or what a track looks like!
Best wishes in your search!
Myb3350
B3350 JD430 Moline BG and BF
Jul 4, 2016
89
meridian ms
Hey may I suggest getting as Cab I have the sister tractor B3350 CAB AIR love the tractor, 65 yo and i don't want to eat anymore dust, those days are over for me lol and I love the small bucket pin on, i never take it off and it never the get in the way, also if your not careful the quick bucket can be dangerous, we have have some people down here get killed by a bucket coming off they thought it was on good but it came off.I know they are convent but be careful with them
