And run the compressor after the tires are filled to purge it out.It won't hurt it if it's running and blowing air before you attach it to the valve stem, so yes a non issue.
Ray
Put the loader bucket on the ground with some down force, that will keep the front end from pivoting on the pin. I just put put rear wheel spacers on my BX, I jacked it up in the center on the drawbar with the bucket on the ground to stabilize the front end. I took the rear wheels off one at a time with no problem. To check the tires you will still have the wheels on and will just be up enough to clear the ground.Thanks D2, Larry, now it makes sense, the plane of movement is vertical. Couldn't see the pin, too much stuff up there, but looks designed to allow axle to move relative to driveshaft. Bet that's why there are all those grease fittings under there ...
Ron, I looked at where Kubota recommends you jack up the tractor in the rear, and it may be a cold day you know where before I try that out. In the owner's manual they have exactly 3 sentences on how to do it.
"Before jacking up the tractor park it on firm and level ground and chock the front wheels". Ok.
"Fix the front axle to keep it from swinging". Huh? How?? must be that pin???
"Select a jack that withstands the machine weight and set it up as shown below. "(Arrow points to the receptacle for the draw bar). Seems like it would teeter if balanced on that.
Pretty sparse. I imagine there is more information elsewhere, since this is a major safety issue, but my car has better info on jacking than this. Another learning issue...tomorrow!
