When operating your backhoe on your BX23S…How do you all orient your FEL bucket? I’ve seen it two ways.
Method “1” You place the bottom of the FEL bucket flat on the ground and lift the front tractor tires off the ground a bit.
Method “2” You curl the FEL bucket all way out(dump) and place the cutting edge on the ground.
Method “2” makes me think there is a high probability of damaging the FEL bucket curl cylinder or the loader frame?
Your thoughts…???
Your thoughts…???
