Need more information to help you out, have you looked up what the codes are?
This is what I’ve found regarding the codes...
U0081 / 523548-2: CAN-KBT frame error
Behaviour during malfunction:
• Insufficient output
Detection item:
• CAN-KBT original frame error
DTC set preconditions:
• Battery voltage is normal
• Key switch turn OFF to ON
• Starter switch signal (ECU: B-
54 terminal) is not activated
• No error of "CAN2 Bus off"
DTC set parameter:
• CAN2 KBT frame error open circuit or short circuit
Engine warning light:
•ON
System action:
• Forced Idle (Accelerator = 0 %)
Recovery from error:
U0082 / 523591-2: CAN CCVS (Parking SW and Vehicle Speed) frame error
•None
Detection item:
• CAN CCVS communication stopping
DTC set parameter:
• CAN CCVS frame time out error
•ON
System action:
• Parking SW = OFF, Vehicle speed = 0 [default value]
9Y1200192CRS0839US0
U0083 / 523592-2: CAN CM1 (Regen SW) frame error
•None
Detection item:
• CAN CM1 communication stopping
DTC set parameter:
• CAN CM1 frame time out error
•ON
System action:
• Regeneration inhibit = ON, Parked regeneration switch = OFF [default value]
