Exhaust manifold For V1702 Motor on L355ss
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Need Exhaust manifold For V1702 Motor on L355ss.
Found one on Ebay for a V1505 but don't know if it will work.
Help
. Go to Tractordata.com, select Kubota. cruise thru the models to find one that uses a V1505 engine and the layout of the tractors exhaust system looks similar to yours. (vertical stack our out the back for example) You may have to google the model for more pics to see exhaust.
. Go to Kubota.com Select parts, Hit OK to the legal mumbojumbo
. Type in to search for your model. Cruise thru the parts schematics to find the one that that has the manifold. write the part number down and part #'s of some of the other exhaust such as pipes that go up or back.
. Repeat process at Kubota.com / parts / search for your L355ss / find manifold and piples
. compare part #'s
5,123
Unless you've swapped motors in your L355ss you don't have a V1702, you have a V1701.
No a V1505 is not the same bolt pattern.
5,123
My 355ss has a 1702A engine. Just purchased a manifold from kubota for the same $ as after market
How did you determine that you have a V1702A engine?
All my research and information only shows that model equipped with a V1701A.
And the V1702 didn't exist when that model was first made, it came along in the middle of production and thus was never installed in it.
The V1702 or V1702-IDI was never equipped in a tractor, only a backhoe, the KH90.
The V1702 IDI was also very popular and common in a Bobcat 743, (I have that model Bobcat) I also have a V1702 that is now just parts.
Then the V1702-DI-A was equipped in the proceeding version the L2850
Did you buy it new or used?
It is possible that if you got it used that someone has swapped the engine.
