diesell leak after bleeding injectors L1801
Kennydog1
Kubota L1801
Feb 24, 2014
21
winnsboro, La
Changed filter and had to bleed injectors. Now lower engine on side of injector pump coated in diesel. Very slow leak of diesel from somewhere. Any ideas where to look first? No leak at injectors.
5,118
Check the fitting and hose on the side of the Injection pump, look for cracks in the rubber line.
Also wash off all the residual diesel with a good degreaser, as diesel will hang around and look wet long after you've fixed the leak.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,180
117
Coyote Flats,Texas
IMHO diesel isn't as oily as it was in years past. I spilled some diesel on concrete a while back and it evaporated. How tight did you tighten inj lines?
coachgeo
Nov 16, 2012
2,460
32
Southern OH
I assume not but just for shits and grins, if you leave the fuelcock on (L235) it should not be able to cause diesel to leak out anywhere PAST the fuel filter (AKA up at the IP)
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Got verified. The fuelcock was on where the tractor was parked for about a week. The IP is soaking wet and a good amount of diesel below the tractor? Could open Fuelcock allow this to happen if there is a problem somewhere or maybe even if NOT a problem somewhere..... just what happens if the Fuelcock is left on?
4,541
Have you tried cleaning off the ip and see if you can see where the fuels coming from? Could be a pin hole right at the hose clamp for the fuel line attaches. Could be an issue with the air bleeder not sealing off, or faulty. Or something not seated/ sealed correctly
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Leak appeard after sitting for a week. Tractor is not at my home so I don't know how slow etc. Mention it in this thread because similar situation to Original Poster. We bleed the engine to start it. Then it sat for a week. Leak found end of week
5,118
Sounds like you have a seal in the top of the injector pump or a line that it leaking. ;)
