Dashboard issue on BX25D
Franceco
BX25
Jun 29, 2016
Portland
Good Day,
My Kubota BX25D is having some dashboard issues, the water temp and gas digital gauge are bot flashing.
As I turn the key to power on , nothing light up beside the illumination on the dashboard and the digital scales.
All other LED stay off.
The engine seems to run fine, but without any warning light and temperature reading I don't feel confrontable running it.
Does anyone have any idea ? is there a faulty wire? I did check the fuses.
I found a service manual for a BX25, but is a old one and the dashboard have analog gauges. does anyone have the newest one for the BX25D ? I will appreciate the eclectic portion of it and the disassembly of the dashboard.
Thank you guys!!!
2,234
Has this machine been outside in rain or even under cover when raining?
2,234
Hi 85HokIE yes sadly was outside and rain on it .
If you do a search here ..... BX25 dashboard .... you will find a good bit of info on what several people have done --- they have gone into the connectors...... cleaned them out and resoldered some stuff to get it back into shape.
A start here ...........
https://www.orangetractortalks.com/forums/threads/bx25d-instrument-panel-and-water-damage.24954/
more
https://www.tractorbynet.com/forums/kubota-owning-operating/297223-help-remove-bx-dash-panel.html
Franceco
BX25
Jun 29, 2016
Portland
more
Thank you the link, it make sense. I will take it apart this week and work on the connectors.
