Good Evening,
A while back I rebuilt a 2 cylinder (Z482) engine for a generator project, well the project has been indefinately grounded for now. In the mean time I would start it from time to time to keep oil on all the moving parts. As I dont have this in any equipment, there is no cooling system attached. Here is the qustion, I keep the block drain open. After a short run of a few minutes I have some oil dripping out of the block water drain how ever it does not drip when not being run.
I was cautioned by another member about the head because of some discoloration notice on the block during disassembly. I did visually inspect but did not maganaflux or dye check it. Is there any way to verify wether the head or the gasket, or possibly the oil passage o-ring, has failed without a teardown?
Thank you.
Thank you.
