Bx25d mmm
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
Hello all!
Quick question hopefully, I was just told that the 60" drive over deck isn't compatible with the 25D. Does that make sense or is something off?
Thanks in advance for the help!
Ron
2,193
Hello all!
Ron
I do not know for sure - but the linkages would not work in the current situation with the BX hanging assembly. I bet the drive on deck had more gizmos on it than the BX standard deck thus making the pinning point out of alignment.
just a swag though....
RonBoyBX25D
Aug 1, 2015
477
Minneapolis, MN
Thanks, would like the drive on if possible. If not then it is a little more work s couple times each year I guess.
2,193
It really is not that bad IF you are on nice smooth flat surface to work on:)
Now getting it back on in a gravel driveway just suuuuucccckkkkkssssss;)
RonBoyBX25D
Aug 1, 2015
477
Minneapolis, MN
That was the concern, guess I will need a sheet or two of plywood for implements.
I found out on the BX25 the drive over only works with turf tires, I need to have R4 for a majority of the work at the lake lot.
Also heard that there will be a kit next spring to adapt the current 60" to drive over regardless of the tire type.
Thanks for all the help everyone!
