BX25 in a dump trailer?
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
I need a trailer to hual my tractor, I also want a dump trailer and would like to combine the 2. Will it work to haul a bx25 in a dump trailer?
3,813
I see no reason why it wouldn't work. Duel axels electric brakes, and a set of ramps and make sure it can handle the tractor weight,+ 10% (that's just my rule of thumb}. And don't forget proper tie downs too!!!
I don't think I would want to try and tilt it to load and unload it. If I am not mistaken I do believe that Wildfire uses his dump trailer for his BX too
Craiger265
BX25D
Apr 26, 2015
27
Manitoba Canada
Here is my BX24 in a Big Tex LP70. Normally the BH bucket is secured to the the back of the trailer.
Where you are Kubota Man is that legel and ok to do that? I always wondered if I could do that with my BX25. I want a dump trailer as well but thought I would need a 14' to haul and then I would have to upgrade my truck to a 3/4 ton. If I can leave both attachments outside of the trailer I might consider this now. Anyone know where I can find out the laws In Manitoba about this?
2,965
No problem here if it has proper tie-down points inside. Know several people who do it regularly. Just don't put a load in it first. :D
A knothead on southbound I-17 put a load of dirt/gravel in his, then drove the tractor (a BX25, from what the wreckage looked like) up on top of the mound, & tied it down. Apparently he didn't realize it would settle- the straps went slack, & fell off. As he headed down Sunset Point (a serious mountain grade) the tractor rolled out of the trailer on a fast curve, with predictable results. Kept traffic stopped for a couple hours. Hell of a waste of a nice tractor.
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Yes it is. I have been all over the states of Washington, Montana and my home state of Idaho. I have never even gotten a second look by the State Police or DOT inspectors. I also have asked a State Police acquaintance if he seen anything wrong with it he said nope. If you had a 3pt mower or similar implement hanging off the back there may be issues with that. As far as the Tractor, FEL and the BH they are all secured to the trailer.
Craiger265
BX25D
Apr 26, 2015
27
Manitoba Canada
Well I finally talked to a DOT guy and he said I'm totally legal if the FEL and BH are outside the trailer. In Manitoba you are allowed 1 metre to extend out from either end of the trailer. Also the FEL and BH have to be chained or strapped to the trailer. Can not be just hanging out with no secure attachment. I will be going with a 12' for that little extra room. The dump trailer will really add to my business!!
Tooljunkie
May 13, 2014
4,150
Just saw this. My good friend uses his dump trailer to haul "Bob". His skidsteer. Contractor with employees. He believes in proper legal transporting. Also, i have coffee with a highways inspector(now retired).
