bx25 bucket capacity & lifting ability?
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
as in the title guys, any ideas on the lifting capability of the BX25 backhoe setup, also biggest digging bucket it can accomadate , any possabilty it would handle a clam grab attachment.
rob
5,128
What do you have a BX now too??? I'm thinking you have far too many Kubota's and you need to share!
Rob
Nov 22, 2009
679
Leafy England....
well then, you never know :);)
Sharing if fine with me, only problem that i can see is this, a lot of miles inbetween...;)
rob
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
I think you're going to need an amphibious Kubota to navigate the big pond.
Here are the spec's per manual:
Digging force of bucket 8610 Newtons
The lift capacity has a very wide range, depending on the arc of the lift. Range is 262kg at the beginning of the lift to 192 kg towards the peak of the arc.
Buckets available per standard are 8" and 12".
Take a look at Wilffire's mechanical thumb. He modified the thumb from static to hydraulic.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Watch out!!!!!
With all that lifting cap'y, now that rear end goes up in a hurry if the load is heavier, as when pulling stumps.
plumcrazy704406
40
toronto
Would this be the same on a bx25d?
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
I would think so... actually my dealer gave me a BX25D manual for my BX25 so that BH info was for 25D. As far as I can tell, comparing the owners manual to my WSM for BX25 the thumb assembly seems to be the only difference I can see between the two.
Is that a 1970 Cuda?
