Anyone know if you can use a mid mount deck without removing the backhoe? I am still waiting for mine to arrive and not sure if the backhoe or loader use the hydraulics that would raise and lower the mower.
No it is adjusted by the 3pt lever.Does the mower deck raise and lower with the FEL joystick?
The BH on the BX23S has a cam device that captures fixed pins on the back of the tractor. Your stabilizer lift hint works in a similar fashion, allows pulling and turning the cam lock levers with much less effort.I cussed and wrestled and worked up a good hatred for removing/installing my BH the first year, dreaded it. Then one day I figured out a touch of left stabilizer lift presto that pin falls right out, then a touch of right stabilizer lift presto that pin falls right out. So stabilizers as the final nudge to take the weight off the pins, after discovering that it was effortless to remove/install and took like 2 minutes. Much happier BH owner then.
I put a tooth bar on my B2920 bucket, raised the bucket like a T-Rex and plowed through my 8 foot tall blackberry patch and ripped those things out by the roots ROAR. lol This is an invasive species of blackberry we have in the pacific NW, Himalayan, the cains can grow 40 feet long.The BH on the BX23S has a cam device that captures fixed pins on the back of the tractor. Your stabilizer lift hint works in a similar fashion, allows pulling and turning the cam lock levers with much less effort.
And after moving to WA from the southeast a few years back I agree with you. Death to blackberries! I grew up in Alabama, our kudzu was something to behold during the summer, but at least it didn't have thorns!
