HI,
I have brand spanking new Kubota BX23S that starting having a strange problem (it has less than 20 hours on it). Whenever i would go down a steep hill, the engine would sputter and die. Yesterday I was cutting a trail in the woods and was on the downhill run, it would die every time I put my foot on the HST!
First thing I thought was that I was running low on fuel, and since the tank was less than 1/2 way, maybe it was not picking up fuel. Not the case.
Looking at the forums I was seeing suggestions about clogged fuel filters, dirt in the tank, the float not set right in the carb, etc. All things that should not have applied to my new tractor.
The problem turned out to be me!! My butt in particular. Whenever I was in a dicey area, or should I say felt dicey due to the off camber nature of the hill, I would shift in my seat...causing the cutoff switch located under the seat to trip. So, by simply tilting the seat back a bit when working downhill, it forced me to sit deeper into the seat, ending the problem
Thanks for listening, or reading I should say!
-Dan
-Dan
