My 2380 has a Curtis cab, so the center of gravity is higher than the norm. I have 2” wheel spacers and filled tires. That combination helps immensely. We are logging about 40 hilly, bumpy acres and was thinking of adding the G8100A wheel weights to help plant the tractor to the ground even better. I’ll be working with a grapple, FEL and back blade to clean up. The Kubota manual says not to run both weights and filled tires to prevent transmission damage. I find it hard to believe that adding another 50 pounds to each wheel is going to put the transmission at risk. I don’t want to damage anything or put the warranty at risk, but I don’t want to end up on my side either. Any thoughts?
