BX23 weight
John T
2017 BX23S
May 5, 2017
741
196
under a rock
According to the spec sheet, the BX23S weights 1570 lbs.
I assume that is tractor only..?
anyone know what the weight is with the backhoe & FEL ?
sagor
Jan 9, 2017
272
50
Sudbury, ON, Canada
Assuming my BX25 is about the same, I believe the total weight with FEL and BH is around 2500-2600 lbs
For the BT601 hoe, weight alone is 578lb without bucket. LA240 FEL is 375lb and bucket is 132lb.
The BX23s would have similar weights
3,234
I think Sagor is spot on. I had always thought my old BX23 at right around 2600. I can no longer find the documents that had actual weights. Tractor close to 1600 and another 1000 for loader and backhoe.
2,171
These number are very accurate - but IF you have loaded tires, add another 200 lbs more or less - fuel if full would add....40 more pounds, and any add ons will add weight too......lights, toothbar....etc:D;)
2,826
Why do you want to know? Are you planing on trailering it?
John T
2017 BX23S
May 5, 2017
741
196
under a rock
Just thinking out loud....
I scored a snowmobile treller the other day.... I figure the weight capacity it around 2k ?
not sure the future of the trailer yet, I have a big car trailer if I need to transport the tractor.... just thinkin thats all...
"sometimes when I think.... nothing happens... "
-Curley [emoji3]
sagor
Jan 9, 2017
272
50
Sudbury, ON, Canada
No way that snow machine trailer, with those small wheels, can carry a BX23S. I would not even use it to haul a bare tractor either. I just don't think that axle is heavy duty enough.
Most snow machines weigh in around 500lb, +/- some. That trailer is probably rated 1000lb or maybe 1200lb load capacity.
John T
2017 BX23S
May 5, 2017
741
196
under a rock
That trailer is rated at 2k
That said,
I agree.
For now the trailer is yard art.
Parts is parts.
